Engine stutter at 1500RPM only? #1001753
05/28/11 11:49 PM
05/28/11 11:49 PM
65Valiant Offline OP
super street
super street
Getting an engine stutter at 1500rpm...give it some more gas and the rpms jump and all is fine from what I can tell.
318, electronic ignition, start the car every few weeks, run STABIL in the fuel as well.
Ideas?
Re: Engine stutter at 1500RPM only? [Re: 65Valiant] #1001754
05/29/11 12:07 AM
05/29/11 12:07 AM
Ideas?
when did it start? What carb? part or wot? is it pretty much non responsive just at that point
Re: Engine stutter at 1500RPM only? [Re: RapidRobert] #1001755
05/29/11 01:40 PM
05/29/11 01:40 PM
super street
super street
Just yesterday, car sits for a few weeks at a time usually.
edelbrock 1406 carb, only does it at part throttle from an idle, then the rpms jump up after the stutter and all is fine, even at WOT. Unresponsive only around 1500rpm. Even when driving the car will jump forward after that rpm.
Re: Engine stutter at 1500RPM only? [Re: 65Valiant] #1001756
05/29/11 06:31 PM
05/29/11 06:31 PM
idle it for a minute (on a level surface) then pull the rods/top & the fuel needs to b at the notches in the float baffles on each side. I think the dry float setting is 7/16". Need a .098" or richer pri jet(s) in there and I'm assuming this stumble is when warmed up/part throttle & if happening during warm up in addition the elec choke can come off way too fast causing a lean stumble and hurting your gas mileage if that is imp. If richening it helps the part throttle bog then concentrate on dialing in the "cruise" step & might note what springs are in there and can run a vac gauge out & taped to the windshield to find when the bog is. Get a baseline on all the details
Re: Engine stutter at 1500RPM only? [Re: RapidRobert] #1001757
05/30/11 07:23 PM
05/30/11 07:23 PM
super street
super street
Started by cleaning out the carb, and shot a video of how when I hold the rpms exactly at 1500, the rpms jump up a few, then back down to 1500, then up a few again.
