Dyno play. #1001748
05/28/11 11:43 PM
05/28/11 11:43 PM
Grande Prairie, Alberta, Can.
CW25 Offline OP
CW25  Offline OP
My work bought a trailer dyno and we were training on it today so I got to stick my truck on it for a few runs. It made 525 RWHP 5300 RPM and 615 RWTQ at 4200 RPM at 8 psi. I didn't have much time on it so I upped the boost to 12 psi and made one run before I had to take it off. It made 581 RWHP at 5000 RPM and 694 RWTQ. It was pretty rich at 10.5:1 AFR. I had noi time to tune but I thought it did alright being such a mild combo. Pump gas 91 octane. I think my springs may be a little weak or the small turbine stock manifolds are causing backpressure issues. I doubt I will do much as it is a pretty hairy street combo. The 581 pull makes it close to 700 at the crank and it idles with 14" vac and starts every time without so much as a hiccup. So I am pleased... Might measure turbo drive pressure for curiosity.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Dyno play. [Re: CW25] #1001749
05/29/11 12:43 AM
05/29/11 12:43 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
NICE for a mild tune!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Dyno play. [Re: CUUDAK] #1001750
05/31/11 10:36 AM
05/31/11 10:36 AM
IL
furious70 Offline
furious70  Offline
IL
That's enough power that the rest of the ole dodge is gonna be hurtin!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Dyno play. [Re: furious70] #1001751
05/31/11 09:47 PM
05/31/11 09:47 PM
CW25 Offline OP
CW25  Offline OP
Yeah I bought a pretty much rust free '80 for spare parts. That rear diff will probably be screaming for mercy. LOL I am kinda afraid to try it at the track but probably will anyways.
Re: Dyno play. [Re: CW25] #1001752
06/02/11 12:33 AM
06/02/11 12:33 AM
CW25 Offline OP
CW25  Offline OP
Well the results are in. I just got back from a test drive and I have excessive backpressure. It has right around 36 psi back pressure at 12 psi boost. I didn't think that exhaust side would choke this early but I did get the smaller exhaust turbine. I think I will crutch it along with some 323 gears to take advantage of my massive midrange torque.
