Turbo size? Opinions welcome. #1001469
05/28/11 04:53 PM
05/28/11 04:53 PM
MD
ADakotaRTGuy Offline OP
MD
Looking at what size turbo to go with. 440 small block 9.5:1, W9 heads(unported), MPFI with FAST XFI, stainless steel manifolds T4 flange (1 5/8ths), 727, 3.23 gears.
Looking to push about 10psi on the street and 14-18psi at the track.
Looking at something in this range.
87mm 1.25 Turbine housing T4 4” downpipe.
Good? Opinions?
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001470
05/28/11 06:09 PM
05/28/11 06:09 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
Do you have any parts yet? If you're starting from scratch with those cubes, go T6 and look at something like a GT47 88.
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001471
05/28/11 09:20 PM
05/28/11 09:20 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You need something bigger than a T4 flange if you plan on a single. If not, you're going to seriously limit yourself on power and have insane back pressure.
- Stu Harmon
Re: Turbo size? Opinions welcome. [Re: feets] #1001472
05/28/11 11:54 PM
05/28/11 11:54 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
If it is for twins a T4 is good. Single you need a T6 and at least a 88mm probably better off with a 91... What are you looking to make for HP. Boost means nothing those W9 heads will flow alot.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Turbo size? Opinions welcome. [Re: CW25] #1001473
05/29/11 01:10 AM
05/29/11 01:10 AM
MD
MD
Right now I don't have anything. Not even a wastegate or anything. Just the motor. Space is my limitation. I was looking to do about 1000hp or about 800 to the wheels.
This is my old setup with a 408 and a supercharger. All the A/C stuff is gone as well as all the other stuff sitting in that corner.
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001474
05/29/11 01:50 AM
05/29/11 01:50 AM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
You think you got space issues now?? Think about where your 5 inch DP is gonna go with a T6 like an S480! It is one honker of a turbo! I know, I got one.
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
Re: Turbo size? Opinions welcome. [Re: CUUDAK] #1001475
05/29/11 07:24 AM
05/29/11 07:24 AM
MD
MD
So it sounds like major fabrication or a set of twins.
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001476
05/29/11 12:30 PM
05/29/11 12:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
The twins vs single debate will continue until the end of time.
What it boils down to is packaging. You should use whatever will fit in your engine compartment best.
- Stu Harmon
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001477
05/29/11 12:34 PM
05/29/11 12:34 PM
Reno, NV
W
Wilde Racing Offline
W
Reno, NV
It is, but so is getting an BW s480. It might be easier to fit two 3.5 pipes vs one 4.5-5 inch pipe. plus 5 inch pipe costs a lot of money. a single s480 set-up will still be cheaper than twins, unless you use china turbos. If you have the money you can find a smaller T-6 80+ turbo than the Borg Warner, the Garrett GT-80 is about an inch small height and length.
Re: Turbo size? Opinions welcome. [Re: feets] #1001478
05/29/11 01:12 PM
05/29/11 01:12 PM
MD
MD
Will the 1 5/8th in header pipes work? I am sure I could hack up the fenders and create space. But a 5 inch downpipe won't fit in between the trans and frame. Would have to go to a bumper exhaust or something creative. How illegal is driving on the street with an exhaust sticking out of the front bumper?
This is what I can cut out to try and make something work. This will be street driven.
Old picture, but only one I have of the passenger side bumper. Outline in white circle where the exhaust could possibly go.
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001479
05/29/11 01:55 PM
05/29/11 01:55 PM
HEMPSTEAD TX
CUUDAK Offline
CUUDAK  Offline
HEMPSTEAD TX
You can remote mount it! Somewhere under the bed!! Alot more pipe involved but no worries about where to mount it!
Re: Turbo size? Opinions welcome. [Re: CUUDAK] #1001480
05/29/11 02:39 PM
05/29/11 02:39 PM
Reno, NV
W
W
Reno, NV
Been there, done that. The oil return pump is always a concern.
Re: Turbo size? Opinions welcome. [Re: Wilde Racing] #1001481
05/29/11 02:46 PM
05/29/11 02:46 PM
MD
MD
Yea, not a big fan of the remote systems.
I am sure a good fabricator can make a T6 fit in there.
SDCE does make a twin kit that will fit.
http://www.sd-concepts.com/pages/cfTurboDakotaRT.cfm
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001482
05/29/11 03:27 PM
05/29/11 03:27 PM
Reno, NV
W
W
Reno, NV
OMG, that looks tight.
I dont think you will like driving the truck if you dump the five inch out the front bumper. My truck was WAY lound when I had the 3 inch cut-out open with my five inch down pipe.
Re: Turbo size? Opinions welcome. [Re: Wilde Racing] #1001483
05/29/11 03:29 PM
05/29/11 03:29 PM
MD
MD
Even more reason to go with a twin system. I can do two 3" pipes pretty easily and still be able to run some pipe to quite it down and be able to enjoy it on the street.
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001484
05/29/11 04:41 PM
05/29/11 04:41 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
saw this comming LOL
2000 dakota 418 magnum paxton novi 2k T56
Re: Turbo size? Opinions welcome. [Re: Sick 660r] #1001485
05/29/11 04:44 PM
05/29/11 04:44 PM
MD
MD
Yea, well you can bask in it all you want. I don't like that twin system, but looks like my only real option vice going completely custom. Wish I was home to actually work on the damn thing.
Re: Turbo size? Opinions welcome. [Re: ADakotaRTGuy] #1001486
05/29/11 05:36 PM
05/29/11 05:36 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
I'm doing a Ford Fox body right now, and I think I'm going to dump it right behind the front tire. 5" won't fit under the car, and I don't want to split into 2 pipes.
If you dump a single 5" at the bumper, there may be room to get a bullet style muffler. Might make it tolerable anyway.
Local guy has a GN with a 4" downpipe right in front of the front tire that he street drives, and it's not as loud as you'd think.
Re: Turbo size? Opinions welcome. [Re: EV2DEMON] #1001487
05/29/11 06:11 PM
05/29/11 06:11 PM
Maryland
Sick 660r Offline
Sick 660r  Offline
Maryland
Im dumping mine out the fender under the antenna. I will only see a few street miles so im not that worried about it.
Re: Turbo size? Opinions welcome. [Re: Sick 660r] #1001488
05/29/11 06:16 PM
05/29/11 06:16 PM
MD
MD
At this point I might forgo the entire turbo system and just slap some headers on it. Pending where I get orders too next I might not see the truck for 2-3 years. No need to dump all that extra money on it for it to sit. I can do that when I come back.
