Re: Swinger hood scoop cut outs.
[Re: cogen80]
#100144
08/05/08 02:22 PM
08/05/08 02:22 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
this what you need?
That helps, I know the grommits go in the holes, but is that it then? No hook up to the air cleaner or anything, just the open holes?
[Re: Dart 340]
#100145
08/05/08 02:33 PM
08/05/08 02:33 PM
Posts: 5,337 the house on the left.
cogen80
this what you need?
yes thats it. the abody didn't have anything hooked to the air cleaner
[Re: AdamR]
#100150
08/06/08 10:29 AM
08/06/08 10:29 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
I put my holes towards the back of the scoop, if the holes are towards the front then when you drive you are trapping air inside the back of the scoop and its a good way for the hood to get squirrely at higher speeds.
I used to own a laundromat so if you want to put some rubber edging on the holes, go to a Commercial Wascomat or Speed Queen distributor and get 1 dryer door seal. The look almost like originals for ALLOT less
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#100151
08/06/08 10:47 AM
08/06/08 10:47 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
The scoops are so low on the hood that they wont pick much air up any ways. I wouldnt worry about trapped air in them. At most they will let some heat out.
[Re: AdamR]
#100152
08/06/08 11:21 PM
08/06/08 11:21 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
The scoops are slo low on the hood that they wont pick much air up any ways. I wouldnt worry about trapped air in them. At most they will let some heat out.
no,they work.and if the heat goes anywhere its under the car
