AVS rebuild question #1001070
05/27/11 09:42 PM
05/27/11 09:42 PM
Mass
r4brightred Offline OP
Mass
I just finished rebuilding my Carter AVS for my 69 Road Runner. I was expecting the Echlin kit to have a thin base gasket, which it did. What I wasn't expecting was a 3/8" thick black composite base gasket also. Does anyone know if the spacer also serves as the base gasket, or if I have to put the thin gasket on the intake then the spacer? I am thinking the spacer may be a good thing because I have fuel boil when I shut the car off on a real hot day and a bit more clearance may keep the fuel a bit cooler. Thanks.
Re: AVS rebuild question [Re: r4brightred] #1001071
05/27/11 09:48 PM
05/27/11 09:48 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
The thick spacer will work as a gasket all by itself.
Re: AVS rebuild question [Re: r4brightred] #1001072
05/27/11 09:53 PM
05/27/11 09:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
It is not a spacer,the thick gasket was standard in 70/71 due to intake and choke thermostat change.It will work on 68/69 but your choke rod will be the gasket thickness short.
Re: AVS rebuild question [Re: 62maxwgn] #1001073
05/28/11 12:53 AM
05/28/11 12:53 AM
I learnt sumpin new today. You could sub in a longer rod & check out the length of an OE one to get it exact then use the thicker spacer which does make quite a diff w the evap prob. If so do check the brass inserts in each corner that they are below the gasket thickness or you'll have a heck of a vac leak damhik.
