Page 6 of 14 1 2 4 5 6 7 8 13 14
Re: Subframe connectors, which way should we #1001
01/19/04 11:12 PM
01/19/04 11:12 PM
Great pics.
Trevor
Re: Subframe connectors, which way shoul [Re: Todd_DesMarais] #1002
01/19/04 11:15 PM
01/19/04 11:15 PM
NY NY
3
340duster340 Offline
NY NY
this was great read! only thing i can add is i dont understand the need to weld the connectors to the floors. i can understand why one would want too, but i dont see what it would be necessary. only because on a full chassis car, the frame isnt welded to the floor.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Subframe connectors, which way shoul [Re: 340duster340] #1003
01/19/04 11:29 PM
01/19/04 11:29 PM
Fort DODGE, Ioway
O
origcharger Offline
origcharger  Offline
O
Fort DODGE, Ioway
"i dont understand the need to weld the connectors to the floors. i can understand why one would want too, but i dont see what it would be necessary. only because on a full chassis car, the frame isnt welded to the floor."
Full chassis cars are not as stiff as you think.
MOPARTS ALERT!: Chris Pugh aka gabodyman of Dalton, Georgia, cashed my $140 money order on 4-16-02 never sent parts. On 3-19-07 he agreed to return my money; "april 9, it will be in the mail by that date""will do as promised. chris" Still no parts and no money!
Re: Subframe connectors, which way shoul [Re: origcharger] #1004
01/19/04 11:47 PM
01/19/04 11:47 PM
Ozark Mo.
BADBEE Offline
BADBEE  Offline
Ozark Mo.
Thanks Tim. Those are just what I needed. Jeff
Re: Subframe connectors, which way should we [Re: ZIPPY] #1005
01/20/04 06:14 PM
01/20/04 06:14 PM
Southwestern Ontario Canada
racealittle Offline
racealittle  Offline
Zippy, I had Bears Performance (when they still built chassis's)tie my frame back in 1981. They put 2x3 straight and parrallel/ through the floor (in and back out) in my Volare. They put detail into the fabrication of the tie-throughs (swedging up at the front and pass through tubes welded in nicely for cables). The car was a small block 4 spd at the time and it made an immediate difference. When I installed the 440/automatic a few years later, I'm sure it helped but the superstock springs/shocks were needed to hook hard. The driver side upper windsheild developped a crack and I can't keep paint in the roof to b-pillar seams. I'm sure that the way I beat on a car it would have folded up years ago without that mod. There are over 23 years and 500 plus passes on the tie job. I can still pick up the car from the tie-though.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen! Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
Re: Subframe connectors, which way shoul [Re: BADBEE] #1006
01/20/04 06:19 PM
01/20/04 06:19 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Todd DesMarais sent me so pics. and I used them to help with my install. I think they were of Zippy's installation. I just finished mine last week. Here are some more pictures. 67 Coronet Just want to add that this is the first time I ever mig welded and I was pretty happy with the results. Just goes to show you that it isn't that hard. The most time saving tool I used was the air body saw that I bought from Harbor Freight for only $20. Made cutting the floors very quick and easy. Right now I'm using it to cut my tubs since I'm also mini tubbing my car. I'm using pics. from Big Block Dart .coms pages. Very informative. I'm glad to have all this info. on this site from all you guys. It makes doing things yourself so much easier. I hope you guys can use my pics. also
rapom
Re: Subframe connectors, which way shoul [Re: rapom] #1007
01/20/04 06:22 PM
01/20/04 06:22 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Picture 2
Re: Subframe connectors, which way shoul [Re: rapom] #1008
01/20/04 06:26 PM
01/20/04 06:26 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
pic.3
Re: Subframe connectors, which way shoul [Re: rapom] #1009
01/20/04 06:30 PM
01/20/04 06:30 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
pic.4
Re: Subframe connectors, which way shoul [Re: rapom] #1010
01/20/04 06:33 PM
01/20/04 06:33 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
pic 5
Re: Subframe connectors, which way shoul [Re: rapom] #1011
01/20/04 06:46 PM
01/20/04 06:46 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Picture of the 3x5's 1/8in. thick plates welded onto the connectors.
Re: Subframe connectors, which way shoul [Re: rapom] #1012
01/20/04 08:01 PM
01/20/04 08:01 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
Rapom, Nice job, that it the best way to weld those connectors in, and not a bad weld job at all!!
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: Subframe connectors, which way shoul [Re: whiplash] #1013
01/20/04 08:36 PM
01/20/04 08:36 PM
Illinois
CRE2004 Offline
super gas
CRE2004  Offline
super gas
Illinois
Great thread!!! Did anyone read the article in MA about the factory style sub frame connectors that e-berg welded in a b-body? Would these be any good for those that don't want to hack the floor pans??
Re: Subframe connectors, which way shoul [Re: CRE2004] #1014
01/20/04 09:00 PM
01/20/04 09:00 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
cre,
Check my pics, I didn't cut the floors. used 2x3x0.125x4' rectangular tube, cost less than $20 plus weld wire
Re: Subframe connectors, which way should we [Re: nomore65BelvJim] #1015
01/20/04 09:46 PM
01/20/04 09:46 PM
Max....do you have any more pics of the installed sub connectors? Maybe one from the side showing the whole length? I plan on putting subs on mine this winter/spring....I'm glad I wont have to cut my new rear pans to install....gotta love the early B's!!!!
Roger that!, and if I can't find em, I'll take some in the AM, when it gets above freezing! I hate laying on cold concrete\
Max
Re: Subframe connectors, which way should we #1016
01/20/04 09:55 PM
01/20/04 09:55 PM
more (drivers side toward differential
Car's so darn long things get fuzzy at the back end Sorry) Wrong picture too, try this one
Re: Subframe connectors, which way should we #1017
01/20/04 10:07 PM
01/20/04 10:07 PM
This is the only area where the floor pan has a kick up. Would have take a lot of filler for this puppy, so I let it slid. Pasenger side by the forward bench seat mounting bolt. It was then butt welded to the T-Bar cross member.
Max
Re: Subframe connectors, which way should we #1018
01/20/04 10:58 PM
01/20/04 10:58 PM
I read about .083 wall, and now .125 wall thickness. Seems the .083 is the favorite, but what about the .125, why is that not more popular? Because of added weight? Anything else? Thanks.
Re: Subframe connectors, which way should we #1019
01/20/04 11:30 PM
01/20/04 11:30 PM
Sparks,Nv.
P
pete Offline
super street
pete  Offline
super street
P
Sparks,Nv.
Here's mine. I used 2x6, cut it to follow the contour of the floor then welded a 3 3/4" flange on it and spot welded the floor to the flange much the same way our trunk floors are attached to the frame. I drilled a 1/2" hole at an angle through the new rail welded in 3/8" steel pipe, cut and ground flat, this is how my emer. brake cable runs through the new rail. I also made torque boxes, did'nt get the fronts in the pictures. still have a little left to do.
Re: Subframe connectors, which way should we [Re: pete] #1020
01/20/04 11:56 PM
01/20/04 11:56 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I heard the same thing you did Challenger. (.083 and .125) I used .094 thickness and it seemed like it would work well. It was a little thicker than the stock frame which is the reason why I think people go with the .083 thickness.
Thanks for the compliment Whiplash
