Oh No! Oil pump pickup tube hitting rod bolt.
#100086
08/05/08 07:57 AM
08/05/08 07:57 AM
Posts: 461 Tennessee
HOOVER24K
super street
super street
Tennessee
I purchased a Kevko M-301 oil pan and was assured it would fit with my 4" stroke crank. Well, I went to put it on and 2 of the rod bolts hit. Its not much so is it OK to bend or dimple the tube to allow clearance or do I need a differant pickup tube? ![](/ubbthreads/images/graemlins/hammer.gif) Thanks, Marlin I haven't contacted Kevko yet to see what they say, will be doing that today.
Re: Oh No! Oil pump pickup tube hitting rod bolt.
[Re: 69Cuda340S]
#100089
08/05/08 10:22 AM
08/05/08 10:22 AM
What rods are you running?
uh oh, didnt you buy a kevco pan?
#100090
08/05/08 11:34 AM
08/05/08 11:34 AM
Posts: 3,333 MARYLAND
69Cuda340S
MARYLAND
Yes I did but I am running Scat i-beams with the cap screws. Should clear without a problem. My guess is the OP is running stock rods.
[Re: GODSCOUNTRY340]
#100092
08/05/08 01:02 PM
08/05/08 01:02 PM
Bend the tube for clearance.
that would cut down on oil flow and plus, those tubes dont bend easy, do they?
#100093
08/05/08 01:25 PM
08/05/08 01:25 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
Id use a different tube When you bend it, you run the risk of reducing oil flow
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: 69Cuda340S]
#100094
08/05/08 01:30 PM
08/05/08 01:30 PM
HOOVER24K
super street
super street
Tennessee
Scat H-beams. I have since called Kevko and they assured me it is supposed to clear so they are sending me another pickup. The tube attaches to one of the main cap bolts (as a support)so it is going to be difficult to bend as it is hitting close to the oil pump. The thickness of a nickel is about all I need.
Thanks for your help.
[Re: HOOVER24K]
#100096
08/05/08 01:42 PM
08/05/08 01:42 PM
is it screwed in correctly? maybe its angled wrong. also, if the oil pump isnt seated right, it could bind up?
are you running arp bolts or stock style main bolts? Arp bolts will hit the oil pump unless you grind the heck out of them (I ran a stock bolt in for the #5 main
#100097
08/05/08 01:53 PM
08/05/08 01:53 PM
HOOVER24K
super street
super street
Tennessee
Stock bolts. I've taken it in and out several times with the same results (twisting and turning the tube in and out) just to make sure it wasn't me. I am using a windage tray main bolt with the bolt on top to attach the support on the tube.
