Timing Chain Covers
#1000780
05/27/11 12:33 PM
05/27/11 12:33 PM
Posts: 2,091 Delray beach, Florida
Performance Only
many racers use one of the currently available billet timing chain covers on the market. i know some make their purchase based on price, others by features and quality. unfortunately the current offerings seem to lack in fall short in a couple of area's. one of the covers available requires the use of a different hub for thr ATI damper and standard dampers are out of the question. another of the covers available is a cast cover and may or may not work with a standard hub damper. neither damper has any provision for adjusting camshaft end play. your pretty much forced to adjust gasket thickness, grind the cam button or some other such procedure. that can be timne consuming to say the least. anyway, we've developed a cover that will work with any standard damper and has a very nice setup for quickly and easily adjusting camshaft end play. i realize this type of item is geared toward a small market, so our first production run will likely only be 25 units. so what are your thoughts on an item like this. should we put it in production?, would you consider using one? we have not put a price point on them as of today. they surely won't be as inexpensive as the cast covers but will likely be more in line with the other current billet offerings out there, albeit with what we feel were needed improvements. your thoughts are welcome and greatly appreciated.
machine shop owner and engine builder
Re: Timing Chain Covers
[Re: Performance Only]
#1000782
05/27/11 01:38 PM
05/27/11 01:38 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
neither damper has any provision for adjusting camshaft end play. your pretty much forced to adjust gasket thickness, grind the cam button or some other such procedure. that can be timne consuming to say the least. anyway, we've developed a cover that will work with any standard damper and has a very nice setup for quickly and easily adjusting camshaft end play. I am working on this issue now. I was going to use a stock cover and the water pump as a stop, but when it goes for dyno work they use elephant ears and I would loose my end play stop. I bought a billet cover based on features and price. It was too shallow. I bought a thicker gasket, cut down cam bolt heads, and the cam button. Now the ATI balancer hits the button head cover screws, as does the water pump. So I must counter sink those fasteners. This is time consuming and I don't have a lot of time to work on this engine. I would have bought your cover, if it was available.
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#1000783
05/27/11 02:07 PM
05/27/11 02:07 PM
Performance Only
that's a nice looking cover. i'm not familiar with that one. who makes it? our design addresses all the issues you mentioned.
#1000784
05/27/11 02:43 PM
05/27/11 02:43 PM
Hemi Allstate
Mt. Eden Ky.
That is made by Cleveland Speed. I polished the face of it, so it may look a little different. I was happy with it other than the issues I mentioned.
[Re: Hemi Allstate]
#1000785
05/27/11 03:31 PM
05/27/11 03:31 PM
Posts: 12,417 Taxes & Virus's R-US, NY
Dragula
Did it come with the timing marker shown?
[Re: Hemi Allstate]
#1000787
05/27/11 03:55 PM
05/27/11 03:55 PM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
This isn't saying much about your market research !!!
[Re: Stanton]
#1000788
05/27/11 03:59 PM
05/27/11 03:59 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
This kind of remarks from some people on this board may be why Dan dosnt post on here very much anymore. He is just reaching out to the fellas on this board trying to aid in areas he knows have an issue. No reason to bash "his reserch" skills for trying to help us racers out.
Dan is a TOP notch machinist that is proved time and again by his work. We need a keyboard cowboy smiley!!
Kasey
[Re: Stanton]
#1000789
05/27/11 04:27 PM
05/27/11 04:27 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
Totally unneccessary!
[Re: Labratt]
#1000792
05/28/11 10:09 AM
05/28/11 10:09 AM
Posts: 3,441 Mo.
supercomp
Mo.
