Re: more electrical gremlins (e body, long)
[Re: jbc426]
#1000747
06/19/11 02:21 PM
06/19/11 02:21 PM
Posts: 2,023 Lincoln NE
440forPOWER
super gas
super gas
Lincoln NE
Ok new update. After unhooking everything from the one side of the ammeter. It hasn't fried the fusible link yet. Not convinced it's fixed. But so far so good. New problem though. Noticed horn wasn't working. When I hit the horn the headlights would go dim. So I replaced the horn relay and when I hit the horn all three wires going to the horn relay fried. As well as melting the fuse box where the relay plugs into. This is so frustrating. I'm to the point of ripping everything apart and replacing the dash harness, ignition switch and turn signal switch.
[Re: 440forPOWER]
#1000748
06/19/11 02:56 PM
06/19/11 02:56 PM
RapidRobert
bring it back home & we'll get on it
