transmission cooler hard line substitute #1000702
05/27/11 09:52 AM
05/27/11 09:52 AM
Marshall, Texas
royt440 Offline OP
royt440  Offline OP
Marshall, Texas
What kinds of flexible lines can be used as substitutes for the hard lines from a 727 automatic to the radiator cooler?
What size or kind of fittings will work?
How much pressure could be present in these lines?
Roy
Re: transmission cooler hard line substitute [Re: royt440] #1000703
05/27/11 10:00 AM
05/27/11 10:00 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
You'll get a lot of answers that border on "ghetto repairs", but other than steel tubing, the ONLY route I would take for flexible lines is braided steel with AN fittings.
My 2¢...
Re: transmission cooler hard line substitute [Re: Commando1] #1000704
05/27/11 10:12 AM
05/27/11 10:12 AM
BDW Online content
BDW  Online Content
Go to the parts store and get some rubber transmission line hose and some hose clamps, has worked for me for the last 10yrs.
Re: transmission cooler hard line substitute [Re: Commando1] #1000705
05/27/11 10:47 AM
05/27/11 10:47 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
My 2¢...
......I would second that statement, except to specify that the braided stainless hose are just that, ALL stainless construction, hose as well as sheath, no rubber hoses with braided SS sheath...
If you have access to McMaster Carr, you could order your flexible ALL stainless hoses, made to size, and end specfications
Re: transmission cooler hard line substitute [Re: DAYCLONA] #1000706
05/27/11 11:43 AM
05/27/11 11:43 AM
Andrewh Offline
Andrewh  Offline
since price per foot of flexible steel lines is pretty up there.
I would consider getting a good bender (around 70 bucks) and some steel line or aluminum from the parts store(10 bucks a line) and bend my own.
I think you will find at the price per foot, you will still save money.
Re: transmission cooler hard line substitute [Re: Andrewh] #1000707
05/27/11 02:09 PM
05/27/11 02:09 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
I bent my own using Cunifer tubing. It is a copper/nickel alloy tubing approved for brake line use by the DOT. It is MUCH easier to bend than standard steel brake or cooler lines. Here is a link to the vender. Read for yourself.
http://cunifer.com/?page=home
Re: transmission cooler hard line substitute [Re: Ramrod39] #1000708
05/27/11 03:32 PM
05/27/11 03:32 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
... GHETTO .....
THEN on the other end of the scale .... braided steel with AN's ...
MUST be nice if you have a boat-load of cash BURIED in the back yard ...
I have used NUMEROUS times ... some 3/8 alum tubing with some high quality braided black rubber hose.
Re: transmission cooler hard line substitute [Re: dOrk !] #1000709
05/27/11 03:48 PM
05/27/11 03:48 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
I've used copper a bunch of times and never had a problem, though the on the last 2 cars I did use steel.
It's just so much harder to bend, and I scratched the hell out of the oil pan trying to get em in there after I bent them up. Next time I going to try that cunifer stuff.
Re: transmission cooler hard line substitute [Re: 440newport] #1000710
05/27/11 04:32 PM
05/27/11 04:32 PM
scratchnfotraction Offline
use some steel line stock with 5/16" comp fittings,bend up new lines and keep the rubber flex down to 4-6 inches if you use any
use the flared ends and brass fittings at the tranz and rad tank,then piece together with the comp fittings for all steel lines
cheap.strong,looks good
Re: transmission cooler hard line substitute [Re: dOrk !] #1000711
05/27/11 05:46 PM
05/27/11 05:46 PM
TP Exit 7, NJ, USA
DANA60 Offline
DANA60  Offline
TP Exit 7, NJ, USA
... GHETTO .....
Wanted to mine with braided, local race shop caries it all, it was $150.00 to do it that way, I think I'll bend mine too. Oh, by the way, it's 5/16 line.
Re: transmission cooler hard line substitute [Re: DANA60] #1000712
05/27/11 11:12 PM
05/27/11 11:12 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
Year One has pre bent stainless steel and mild steel trans cooler lines listed for most A,B,E bodies, 904 and 727 trans, big and small blocks, $59 to $89......however i tried to order some today and they said 1-4 weeks....wonder who else has them? fine lines? Mega parts?
Re: transmission cooler hard line substitute [Re: Joesixpack] #1000713
05/27/11 11:29 PM
05/27/11 11:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Order directly from FINE LINES,....most of the mopar 2 pc line kits are $45 for the 904/727 SmBlk/BBlk.....any of the aux cooler/HEMI kits run $115,.....Hard Stainless Tube is also avaliable for a few $$ more
Re: transmission cooler hard line substitute [Re: DAYCLONA] #1000714
05/28/11 12:24 AM
05/28/11 12:24 AM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
thanks just did order from fine lines,directly,$45 plus shipping....
http://www.finelinesinc.com/
