No Left Turn signal. Help!!
#1000572
05/26/11 11:11 PM
05/26/11 11:11 PM
Posts: 579 Wattsburg, Pa
Dr V
Wattsburg, Pa
Put the Hemi back in after the rebuild did nothing but move the column downward but disconnected nothing electrical.
I have right side turn signal, lights and brakes. Both front and back on the right side. Left side turn signal is super rapid, doesnt light up green light on instr cluster and does not flash the tail light bulb or the front park lamp bulb. Lights, when on, work in all 4 corner. Flasher makes different noises at right and left positions so I replaced it and it fried a new Buss type but works as I described with the original one in it. What is going on here????
69 1/2 A12 BEE 4 spd 1968 Charger 383 1970 Roadrunner 440+6 Survivor 2019 Redeye 2005 FORD GT Red/White 2017 Viper ACR Extreme Red/White 1979 Branco Red/Red 2018 Porsche GT3 Miami 1971 440+6 Cuda 4 speed V2 2020 Sebring Orange Vette 1979 Chevy Boogie Hippie Van
Re: No Left Turn signal. Help!!
[Re: Mopar_Country]
#1000575
05/27/11 02:42 AM
05/27/11 02:42 AM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
Maybe a pinched wire when you bolted the column back up. Did you disturb a ground somewhere maybe. Just thinking out loud.
Possibly. But from symptoms described, it sounds like a very small current is getting out (rapid flasher). Either pinched wire or perhaps the pin in the column harness connector is pulled out from the column repositioning.
Put a 12V jumper wire on the light green in the harness side of the turn signal harness connector to verify power is getting to the bulbs of the dash, front, and rear assemblies. That rules out the harnesses, and narrows it down to the column side of the connector or (more likely) the turn signal switch.
[Re: MoparMarq]
#1000576
05/27/11 09:02 AM
05/27/11 09:02 AM
Dr V
Wattsburg, Pa
Im gonna lower the column today to check for burn or pinches. Thanks Guys
[Re: 68HemiB]
#1000578
05/27/11 02:54 PM
05/27/11 02:54 PM
MoparMarq
Vancouver, WA
b. Too much load (dead short/trailer lights/extra teenager lights) and you get an excessively rapid blink.
Good point. A safer way to check for no short to ground is remove the bulbs from the front and rear sockets, remove the dash turn signal socket from the dash frame, THEN test for continuity with volt/ohmmeter between the light green wire pin on the dash side of the turn signal harness and ground. If there is continuity (resistance = 0), there is a short somewhere in the harness between the turn signal harness connector and the ends, where the bulbs are. What to do?
One method may be to disconnect the forward light harness (at the bulkhead connector) to see if the problem goes away. Check turn signals both directions, to see if they flash at the same rate; load will be different without the fronts hooked up.
Then try the rear light harness at the left kick panel connector to see if it goes away. If the rear running lights and brake lights work properly, it's doubtful the rear light harness is shorted.
If the problem is still there, it's likely in the dash harness somewhere.
That's as far as my thinking goes at this point...
[Re: MoparMarq]
#1000579
05/27/11 05:12 PM
05/27/11 05:12 PM
Dr V
Wattsburg, Pa
Found it. I took down the metal brace for the column and found the bright green wire coming out of the turn signal switch flattened out and a piece of the bare wire was touching the frame. I reinsulated it and replaced the column brace without rushing. All is fine. Thanks again.
[Re: Dr V]
#1000580
05/27/11 07:04 PM
05/27/11 07:04 PM
Posts: 9,312 SoCal
68HemiB
SoCal
Good to hear that things are solved. And thanks for posting back the results. There's nothing more annoying than offering suggestions, only to have the thread trail off into the abyss, with no results posted. Sure makes me less likely to offer anything.
Down to just a blue car now.
