Ring end gap #1000428
05/26/11 07:19 PM
05/26/11 07:19 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I'm putting my 340 +.040 engine back together. What ring gap should I use? Cast pistons .040 over, Moly rings.
Re: Ring end gap [Re: JonC] #1000429
05/26/11 08:01 PM
05/26/11 08:01 PM
top-.016". 2nd-.012"
Re: Ring end gap [Re: RapidRobert] #1000430
05/26/11 08:13 PM
05/26/11 08:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Current thinking is second ring gap should be wider than top gap... It has been found that the second ring can trap pressure between the rings and cause the top ring to flutter in it's groove losing ring seal....
I'd set the second @ .018..
Re: Ring end gap [Re: 1_WILD_RT] #1000431
05/26/11 08:24 PM
05/26/11 08:24 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
That's a bit of a difference between the two answers.
Re: Ring end gap [Re: JonC] #1000432
05/26/11 08:29 PM
05/26/11 08:29 PM
Old school was .004 per inch of bore on the top ring and .003 on the 2nd comp ring as the top ring is closer to the fire and will expand more. New thought is the opposite. The old has worked for decades & is my pref
Re: Ring end gap [Re: JonC] #1000433
05/26/11 08:30 PM
05/26/11 08:30 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Id file them the same, 1st and 2nd groove.
IMO, ring gap, (as long as its not tight) isnt that big of a deal.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Ring end gap [Re: RapidRobert] #1000434
05/26/11 08:33 PM
05/26/11 08:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Nothing wrong with old school, it's worked well for me in the past also... But learning new tricks from guys that have results to back it up isn't a bad idea either...
Re: Ring end gap [Re: Von] #1000435
05/26/11 08:34 PM
05/26/11 08:34 PM
Jonc we're not helping you today are we
Re: Ring end gap [Re: RapidRobert] #1000436
05/26/11 08:50 PM
05/26/11 08:50 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Ha Ha, but I just want to get it back together. I guess it wouldn't hurt a street car to do it old school.
Re: Ring end gap [Re: Von] #1000437
05/26/11 09:27 PM
05/26/11 09:27 PM
WI
Dcuda69 Online content
Dcuda69  Online Content
WI
If in doubt fail on the big side. N/A I would do .016-.018 on both and run it!!
Re: Ring end gap [Re: Dcuda69] #1000438
05/26/11 09:57 PM
05/26/11 09:57 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
That'll work
Re: Ring end gap [Re: buildanother] #1000439
05/26/11 10:29 PM
05/26/11 10:29 PM
California
court9155 Offline
court9155  Offline
California
I go with the .0045 and .0035 all motor rule and .006 and .0045 for nitrous or low boost.
http://www.totalseal.com/TechPage.aspx#trTSFAQ
67 charger
Re: Ring end gap [Re: court9155] #1000440
05/27/11 12:39 AM
05/27/11 12:39 AM
California
court9155 Offline
court9155  Offline
California
Wow did some research and I dont believe everything I read but:
http://blogs.hotrod.com/piston-ring-gap-194.html
67 charger
Re: Ring end gap [Re: court9155] #1000441
05/27/11 12:58 AM
05/27/11 12:58 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
...and you should REALLY question ones who are Really TemperMENTAL
JC ...what do you have for ring gap now? uNless you bought specific OVERsized rings .... normally - very little filing will be necessary.
Re: Ring end gap [Re: dOrk !] #1000442
05/27/11 09:54 AM
05/27/11 09:54 AM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I never thought to measure the old rings, I'll do that today.
Re: Ring end gap [Re: JonC] #1000443
05/27/11 10:34 AM
05/27/11 10:34 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Also in this case I believe in the old adage too much is better than not enough. Read this. http://www.kb-silvolite.com/features.php?action=read&F_id=62
Re: Ring end gap [Re: MoparforLife] #1000444
05/27/11 12:20 PM
05/27/11 12:20 PM
That "flutter" deal may be true for a full out high RPM RACE engine--but for a street unit old school is still a great way to go--doing an 8500RPM Drag small block go the other way. Get the rings on right side up and no matter what you do it will be fine
Re: Ring end gap [Re: JonC] #1000445
05/27/11 12:32 PM
05/27/11 12:32 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
THAT would be an interesting # to see ... but what I am talking about is the NEW rings .. in the NEW bore. And like was said above .. it is BESTer to have the gaps a tad fat .. than toooo tight.
NASTY things can happen if the ring ends butt and then break.
Re: Ring end gap [Re: dOrk !] #1000446
05/27/11 07:04 PM
05/27/11 07:04 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Old top ring is .025, new top ring is .016.
Old second ring is .027, new second ring is .017. The engine bore has not changed in this rebuild, all I did was have it balanced.
Re: Ring end gap [Re: JonC] #1000447
05/27/11 07:09 PM
05/27/11 07:09 PM
You have 016 and 017, I'd run em. OT; Jon What did you do to the bore finish?
