Re: I need a Decent inexpensive 440 recipe
[Re: 73rrak]
#1000296
05/28/11 02:14 PM
05/28/11 02:14 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Should be very easy getting 400 rwhp, my guess, around 470-480 at the flywheel, very easy to do with a 440, This can be done with factory pistons & bolt-ons/cam change on the pre 71 short blocks, if not, this is what i'd do for a later block.
.030", TRW 2355s, block prep. Cleaned up 906 or 452 heads (decent VJ) no porting XE274H or 275HL cam & springs True roller chain set TRW oil pump, doesn't need to be high volume. 1.7/8" headers full length, or even Shoe-Mack. 2.1/2" exhaust. SD intake or RPM. 750 3310 vs. only because of the gears/converter your useing. Good ignition with a nice adj. timing curve in dist..
The car should easialy get into the 12s in a B body. & be VERY street friendly, i'd run pump premium.
[Re: RUNCHARGER]
#1000299
05/28/11 06:17 PM
05/28/11 06:17 PM
joedust451
super gas
super gas
Branson, Mo.
If you want an honest 400HP at the tires I'm not seeing it using stock iron heads with stock valve sizes etc. If you want to use stock heads without spending $2k on porting and preparing them you might as well do a quick valve job on them and put nitrous on top that's the only way I see 400HP at the tires. If you want to make 400HP on the motor the cheapest way there will involve a set of Edelbrock heads a good hydraulic cam and a stockish shortblock with 9.5 or 10.5-1 compression measured. Your torker intake is wrong for a 2000 convertor, 3.55 gears and 4000lbs. your 800 DP is also wrong for those components. I would not use the Six Pack replacement pistons as suggested many times above. You can use them but for $100 more invest in a lighter set of pistons and your engine will live longer. If it was me I'd build a stock shortblock except for something like Diamond flattops. I'd sell the Torker, 800 and all those other BB cast iron. Then I'd get a set of Edelbrock heads and a used Holley Street Dominator intake or an Edelbrock dual plane. When I had all of that stuff figured out I'd come on here for a camshaft and carb. recommendation. (and when I think about it, I'm not so sure there is a camshaft that will make 400HP at the rear wheels and will work with a stock stroke 440 and a 2000RPM convertor). And like I say the other way is to ball hone it, get a valve job done, stick in new bearings, use the Torker, and put a nitrous plate under the 800.
Sheldon
You can make 400rwhp easy with factory iron heads, I made 500 fwhp with a set, he wants to build it on the cheap, This cannot be done with high priced pistons & eddy heads.
Yeah, installing a plate kit is the cheapest.
