Page 2 of 3 1 2 3
Re: I need a Decent inexpensive 440 recipe [Re: ademon] #1000275
05/27/11 01:38 PM
05/27/11 01:38 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
IMO that cam is to big for your 3:55 gear and 2000 stall convertor. Here's the specs for the cam he listed. I would go 1 step smaller with the Comp XE275HL.
LInk for XE285HL cam
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=712&sb=2
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: I need a Decent inexpensive 440 recipe [Re: Ray440] #1000276
05/27/11 02:06 PM
05/27/11 02:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i agree , and with that gear and convertor ANY single plane is the WRONG intake .
Re: I need a Decent inexpensive 440 recipe [Re: GTXX] #1000277
05/27/11 02:32 PM
05/27/11 02:32 PM
Maryville tn
67coronetman Offline
Maryville tn
Yes it is i had a 440 that was .030 over stock rods & KB pistons stock crank bigger oil pan & pick up with cheap oil mods to help out and a 292/509 mopar cam & lifts with 1.5 rockers 850 holley & 906 heads with bigger valves & mild port work along with a TM-7 intake port matched in a 66 satellite full interior 4200 stall 4:56 gears ran a 11:70 et not bad at all.
Sealed Power 6 Pack pistons, Mopar performance 292/.509 cam, Holley Street Dominator intake, 800-850 double pumper, 906 or 452 heads at least bowl ported with 2.14/1.81 valves. Tried and true recipe and as cheap as it gets
Old car are me......
Re: I need a Decent inexpensive 440 recipe [Re: 67coronetman] #1000278
05/27/11 03:14 PM
05/27/11 03:14 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Sell those 915's to Ademon for $500 since he LOVES them so much and use the money more wisely. What makes you think he needs to do any grinding on the 452's? Remember he's wanting 400hp not 600 and with 3.55 gears and a 2000 stall converter on a 5000# car your thinking way outside the box! 400hp with stock valved 452's is easy with a simple cam swap and headers! 915's don't flow better than 452's and to take advantage of quench with closed chamber heads requires domed pistons milled to spec which
A: costs alot of money at shop rates
B: puts the compression outside of daily driver/pump gas usage.
The speedpro 6pk pistons are good pistons but their too heavy IMHO Just trying to keep it light (old habit)
Oh and JohnRR I think his shop is thinking about chevy's with the piston flip.
Re: I need a Decent inexpensive 440 recipe [Re: Dusted_Ya] #1000279
05/27/11 03:45 PM
05/27/11 03:45 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think you have that mixed up, you don't need a fancy dome and milling with closed chamber heads for quench, that is with open chamber heads like the 452's. I just did a build with 452's and quench dome Diamond pistons.
Out of the box the 915's probably flow a little better, ported they flow the same as the 452 which is easier for the home porter to do because there is no short turn to worry about which will kill flow if not ported properly.
Every company makes a 2.065ish CH piston which is what the 6pk piston is , mill for zero deck , use a composite gasket and a closed chamber head , DONE. though in this case the KB's might be the better choice with the CANYON they call valve reliefs to keep the compression around 9.5 and very pump gas friendly.
Dust Ya , I figure it was a brand X engine on the piston flip , small block fords can use that the same thing .
Re: I need a Decent inexpensive 440 recipe [Re: Dusted_Ya] #1000280
05/27/11 04:12 PM
05/27/11 04:12 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
5000# car
73-74 Bs are heavy, but not close to 5k. 4k, give or take.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: I need a Decent inexpensive 440 recipe [Re: Dusted_Ya] #1000281
05/27/11 06:36 PM
05/27/11 06:36 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i have got 915's from guys like you with more mopar knowledge, last set cost me $40
Re: I need a Decent inexpensive 440 recipe [Re: ademon] #1000282
05/27/11 07:36 PM
05/27/11 07:36 PM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
I doubt that. Especially if they're selling them for $40...
Re: I need a Decent inexpensive 440 recipe [Re: Dusted_Ya] #1000283
05/27/11 07:58 PM
05/27/11 07:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
9:1 speed pros' 915's, summit 488 cam, headers, SD intake 750 holley done. low 13's
Coming soon!!!!
Re: I need a Decent inexpensive 440 recipe [Re: Von] #1000284
05/27/11 08:08 PM
05/27/11 08:08 PM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
I'm not planning on using the 915's mostly because I don't know much about the motor their on and I'm sure they would need rebuilt. I have a set of 452's that have been checked and surfaced they will need better springs but other than that they are ready to go.
The weight of the 73 Roadrunner is 3,525 lbs I don't know if that's with a big block or small block so I would guess at 3,800 lbs to be safe
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000285
05/27/11 08:15 PM
05/27/11 08:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
452's will be fine. ran 12.90's in a 67 coronet with maybe 9:1 and unported 906's
Re: I need a Decent inexpensive 440 recipe [Re: Mr.Yuck] #1000286
05/27/11 09:41 PM
05/27/11 09:41 PM
Central NC
gch Offline
gch  Offline
Central NC
Smaller camshaft and lose the torker intake.850 holley is a tad big for your setup.Will it work?Yes.Will it be optimal?No.
Cam around 230*(give or take) @ .050.No need for a high lift cam with stock heads.
Run any dual plane intake.Used Performers are cheap and an rpm a little more.
750 Vacuum secondary would be my choice for carb.
Sell or trade your 850 and torker intake for a dual plane and good 750 vacuum carb.Build for TORQUE.Tons of low end and midrange make a mild geared heavy car fun/happy on the street.Short duration and any more than .500 lift is a waste on stock heads.
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000287
05/27/11 11:51 PM
05/27/11 11:51 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: I need a Decent inexpensive 440 recipe [Re: forphorty] #1000288
05/28/11 01:48 AM
05/28/11 01:48 AM
Alaska
73rrak Offline OP
73rrak  Offline OP
Alaska
Ok so what am I missing here these guys are running pretty much the same parts I already have( low comp 440 torker intake 800 holley) and are saying they run good. Are these guys balancing these motors after they hone and re-ring them or just running them the way they are without a balance? I would love to be able to just hone one of these motors with new rings and have another play toy without spending $2,300 on a motor in a car I'll hardly ever drive.
I better look at this again before I jump and have a motor built.
Re: I need a Decent inexpensive 440 recipe [Re: gch] #1000289
05/28/11 01:51 AM
05/28/11 01:51 AM
The Dalles, OR.
Dusted_Ya Offline
Dusted_Ya  Offline
The Dalles, OR.
Exactly! Kinda what I said without the drunken undertones...
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000290
05/28/11 02:17 AM
05/28/11 02:17 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
go for it i had a bone stock 383 with a small 220 @.050 cam with CC 516 heads, stock 68 intake and carb, headers run 12.50's in a RR.
Re: I need a Decent inexpensive 440 recipe [Re: imfixinmopars426] #1000291
05/28/11 02:25 AM
05/28/11 02:25 AM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
440+6 pistons,.484 cam,perf rpm intake,750 v/s carb,home ported 906's,headers,11.95-12.05 et in street-3500#=cheap fun!
Re: I need a Decent inexpensive 440 recipe [Re: VITC_GTX] #1000292
05/28/11 02:48 AM
05/28/11 02:48 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Sweeeet combo ...
Re: I need a Decent inexpensive 440 recipe [Re: 73rrak] #1000293
05/28/11 04:51 AM
05/28/11 04:51 AM
Adrian, Mi
P
pro6pakRR Offline
mopar addict
pro6pakRR  Offline
mopar addict
P
Adrian, Mi
I need a decent inexpensive engine recipe For a 73 Roadrunner 3:55 rear gear 2000 stall I have a 77 MH block a cast crank 75 HP block and a 67 block. I also have 452 906 and 516 heads. I would like to make 400 hp at the rear wheels.
I had a bone stock 71 440HP,with a 533 mopar cam and a 6 bbl.That ran 12.40's in my 3895# 70 road runner all day long.
Re: I need a Decent inexpensive 440 recipe [Re: pro6pakRR] #1000294
05/28/11 07:21 AM
05/28/11 07:21 AM
kentucky
superbyrd Offline
superbyrd  Offline
kentucky
ah yes. again, someone asking for engine build opinions,have lots of mis-matched parts on hand,and hoping to hear what they want to here....
slap one of those engines together (any of them), use the heads (any of them) all the other parts you have on hand already, and it will make 400HP at the tires .........
that was the answer you were looking for.........
Page 2 of 3 1 2 3
