ok what is the biggist 15 inch wheel/tire combo that will fit under a 69 road runne with out relocating the springs or mini tubbing? not against useing a differnt housing that has a shorter width and moving spring perches but i will not move the springs
would a 295 50 15 on a 15x10 rim fit?
this is for a buddys car
also if anyony one knows off the top the width of a a body 8 3/4? will that work under there in any way???? or no?? the car has no rearend under it at all right now so will have to buy something lets hear/see you combo,s please
