You don't need to modifiy the cooling system, you need to run the right tuneup, I'm sure.
I will check the timing - but I don't see why it would be different than when I drove the 1,000 mile trip to St. Louis. Stranger things happen - maybe the timing chain is stretching and changed the timing?? Regardless - I'll check it. Thank you.
