Hay Rick .. would a 1/2" breaker-bar fit on the tensioner ? Also ... I hear that the pass side motor mount should be uNconnected ...and the motor dropped down slightly ... ??
Doubtfull on the breaker bar, unless it is real thin..You only have maybe a inch in that area.
I`m cheap so rather than buy the trick ratcheting ones, I made my own out of 1/2 square stock and a piece of 3/16 x 1" flat stock.
I personally don`t take the mount loose..that is taking WAY more off than needed...I never even open the hood until I refill it.
Rick
Thats how I do them. All from the bottom.
And be very carefull not to break off the bolts holding the water pump on! If they dont want to come out, A little heat on the housing helps.
IIRC they pay around 1.7 hours to do.
