Okay in the mean time: I've been comparing the '68 wiring harness to the '69 and one of the differences I found is the lack of a Yellow w/tracer wire from the "Light Switch" on the '69 connection at the switch.
Here is the wiring harness I have that DOESN'T HAVE THE YELLOW W/TRACER sitting on a '68 wiring schematic diagram that shows the yellow tracer? I'm starting to think I have a '69 wiring harness that I need
![](/ubbthreads/images/graemlins/boogie.gif)
This Yellow w/tracer wire goes from the dash switch to the front running lights(turn signal) on the '68 and now I think I know why the front running lights go off when you put the headlights on the '68 (rr,sat..) but not on the '69's......
![](/ubbthreads/images/graemlins/shruggy.gif)
MikeR
