you had better repair the check ball in the trans line up by the radiator or you will tear up the support again as the lube circuit to the support and intermediate shaft gets cut off by a stuck check ball in the line also check for good cooler flow..better yet remove the check ball and put a full time lube kit in the valve body
70 cuda 440 6bbl Auto with a dana 60 68 road runner QQ1 383 auto 1970 6 barrel 4 speed Superbird FY1 number matching 15 Challenger 6.4 SRT pearl White 6 Speed 72 Cuda 440 5 speed 71 Road Runner 440 4 speed
