What type of tires are you running ?
An old style tall sidewall 15" tire will flex alot more and probably need more clearance than a modern low profile 17" or 18" setup ?
I usually just shoot for having room to fit my fingers in between the tire and quarter and go from there.
(3/4" or so?)
probably 15 inch tires-with alot of sidewall like a 275 60 R15
Put a big block 4 speed Scat Pack Dodge in your garage.
