if you have rears flashing, flashers has nothing to do on fail.
the only way you can get fronts failing and not rear ( hazzards or turning ) is turning signal damaged or related wires broken or loosen at plug.
front an rear circuits are separated to be able to feed brakes just to rear.
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
