I have a BeCool aluminum rad with the SPAL dual 11" fan assembly that I was planning to use in my project. When I initially fitted everything, the fans cleared fine but I had a small change of plans and I am now using the March dual belt serpentine setup for the alernator and power steering. The new mounting for the power steering pump now interfers with the left side fan motor. No easy way that I can see to get around this problem so I tried mounting the assembly as a pusher fan setup but I am not sure how effecient this will be. From what I can gather the fans will push air this way (reversing them electrically) but it is not nearly as effecient or a recommended configuration. Has anyone used these SPAL fans (30102052) as pushers or if not, any suggestions for another fan or fans that may work. If there is an OEM dual fan that places the driver's side fan lower than the passenger side, I think that may work.
