From the FSM: Measure distance from lowest point of one adjusting blade to floor and from lowest point of steering knuckle arm to floor. The difference is 1-7/8" ±1/8"
The picture shows them measuring on the inside of the control arm on the round part of the adjuster blade, and the bottom of the ball joint that they call the knuckle. The ball joint is lower than the adjuster.
