Pretty much now way to check it.If the clutch didnt make wierd noises its probally OK.When you pull a vacuum hold it for a while to see if it drops.The dryer is a good idea to replace.Just remember to evac the system before you unhook anything.They still can have 134 in them and not turn on the compressor.Rocky
Chrysler Firepower
