As mentioned Id use the 75 or 78 block, steel crank and the 915s.......
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
