I'd use the best parts from all 3. Ideally you'd want to use the 67 block and heads. If you are going to buy all new guts I'd use the block/heads that require the least amount of machine work. Hard to say w/o seeing all of it.
If you think he should use the best of all 3 what leads you to believe the 67 block is BETTER than the others ?
meaning if the bore on the 67 didn't require bore and new pistons I'd use that.
