as someone else posted, 14 gauge is fine for the control wiring for a relay, but it's not big enough for running the pump. I would use at least 12 gauge, 10 ga wouldn't hurt if you're running 20+ feet of wire to hook to power.
Agreed!! I always run 10 gauge for the supply on an elec. pump, 8 gauge wouldn't hurt either, 14 gauge is way too small.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
