I took the two wires.........the dark bl and dark bl w/tracer and connected to inside terminal of new reg (ign side). I also connected new field wire to this same terminal. OE field wire is connected to outside terminal of new reg(field side). It was charging before the switch.......now its not. I wonder what I did wrong???????
