I use the hi temp silicone on both sides of the fel-pro gaskets and they seal perfectly and become reusable as only the silicone sticks, not the gasket. I never tried silicone only, but like someone above said, if your flanges are true, it oughta work!
I always used gaskets when the flanges have the welded bead on the head surface. You just dont have as much surface area for the silicone to seal up when its like that.
Nope. Russell at Mancini said his shipping dept. messed up.....
If the flange is flat with no welded bead on it I just used silicone like the others say.
Also, I would think the wrong gaskets in the box would be a TTI issue and not Mancini.....
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
