I don't plan to pull the heads as this motor ran fine when it was pulled but was in a power wagon with a rear sump pan. I pulled the pan to change it and its more curiosity then necessity that I find out. I'm gonna run this motor either way. I'm curious but not enough to pull the intake and heads. Thanks.
