All the old TRW or Speed Pro 340 pistons I've ever seen had some sort of grey area on the backside of the dome and some sort of triangular logo "cast' into them. The piston numbers were usually stamped into the flat machined area on the dome. Posting a close up pic of the dome and valve notches, and the underside below the pin bosses, might get a better response
