You really need to measure it. No telling what the original height was (it varies) or how much was really taken off to clean it up.
What heads are you installing? If you are running closed chambered, the combination won't work unless the quench dome was removed, or you have a really tall deck. Might have to run a thick gasket.
Again, you really need to measure once you get the heads off.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
