Its etched into the paint. You will probably need to compound and or wet sand. Im using Mequaires 205 and 105, Use the compound with a yellow pad @ 1400 rpms, The polish with a yellow pad @ 1200s, then with a black pad @ 900 rpms.
Top the paint off with a good sealant then at least 24hrs after removing the sealant wax it.
