The electric fuel pump that I'm using requires a larger line than what is on my RamCharger which also means that I have to change the dip tube size on my sender To do this I was going to use a 90 degree bulkhead fitting & attach the larger diptube to it. All using #8 AN style fittings What would you use ? Aluminum or steel for the tube?
