KRIOL will do the trick spray the top and left it soak in.Then do it from the bottom.Couple times a day for a few days.Be patient.A few hits with a deadblow hammer on the pistons should finish loosening them.You may need to sleeve a few holes if they are rusted too bad.
Leave the gun.......take the Cannoli's....Mike
