thanks guys!! i knew moparts would come through. i also thought it might be a thrust button that fell off of the pin but i had looked and they were in place. i've removed the pig so i may try mounting it on a engine stand to try the wiggle and push method and if that won't work i'll loosen the bolts and try. thanks again! dave
