My worry is what head are you going to try and use?
I'm pretty sure the wedge heads that can fit a 2.4 valve all need a min of a 4.5 bore. Although I could be wrong.
I was going to run my B1m/c with a 2.4 valve on a
4.440 bore... but I didnt like the shrouding ...
this was going to be a 9000+ rpm engine(514ci)
Morgan says use a valve that is 52-.525 of the bore for all wedge heads and .53-.535 of the bore for canted valve heads so that would be a 2.33in valve for that B1 combo.
This question was more of theoretical thing for my purposes. And lets just say I'm tinkering around with cylinder head design. Thanks for all the help, I pretty much found what I needed and more. These forums are great for the brain sometimes as I'm constantly learning more and more. Thanks again
You guys also gave me another question to ask. I will put this one in the boosted forum though.
Adriel Paradise
Substation Design Engineer III
