Will need to know the specs on the cam and valve springs before anyone can make a recommendation.
Why would you need adjustable pushrods? I ran a lunati voodoo 60303 cam with stock rockers and stock pushrods.
Rule of thumb is HD stamped rockers are good for .5" lift. Perhaps a bit more on a moderate RPM stroker with moderate springs. It depends on the cam/spring combo.
