I just got my 340 stroker back. Eagle stroker kit i used a Hyd roller muther thumper cam 235 249 @50 duration from comp cams. I got RHS heads with Hughs racing springs.Comp rollers and lifters.I do not have this in my duster yet. I would look at a HYD Roller cam if i was you the guys at comp will work with you.
