Picked up a 440 engine that has VIN #s (I guess)stamped at the oil pan rail but nothing on the upper pad. What gives? Not sure what the engine came from but it was freshened up and has new flat top pistons.
If the vin starts with 1G1 it is a for 1971 St. Louis built car. Probably a B body. I do not believe any LP 440 engines were used at St. Louis. So it very well may be a 71 HP motor. If the VIN # is 1C1 it could be LP or HP. Not sure why there are no stampings on the top pad.
