Re: How to install 5.0 kickdown lever
#95959
07/28/08 12:37 PM
07/28/08 12:37 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
dang, no its not. Im guessing this is a "remove the front pump and then ....." type of job, right?
no , there is a small 1/4 drive pipe plug behind the convertor , you pull the plug , loosen the band linkage , remove the band struts , slide out the pivot shaft , swap the lever , slide pivot shaft back in , put the plug back in and replace the stock band strut with an HD piece because that 5.0 lever will probably bend it overtime .
whats in the trans again ??
