I run the blue cams on 1 and readjust the pump arm.
Then you can try larger or smaller squirters from there.
Also, take a vacuum reading at idle in gear and use a 2" smaller PV than the lowest reading you have. If you have alot of vaccum, use a 10.5 PV and then you may need a larger squirter (35).
Brian
Brian Hafliger
