Yes, that cam kit is used for all the holley carbs...2300 is the 2 bbl series{including the 6-bbl set-up}...4150 is the mechanical secondary carbs{double pumpers} and the 4160 is the vacuum secondary carbs{your 3310 included}... ...Here's that acc. pump cam chart right off the holley site...
