Roof skin was removed to have it chemically stripped. Someone along the line DA'd some of the outer panels and never primed them. The metal was pitted so we chose to strip the roof. Also replacing the upper cowl with a mint original. It is laying in place in this photo. Mine had some dents, dings as well as some rust thorugh in the lower window channel.
You can alos see in the photo that someone robbed the Z bar mounting bracket and part of the frame rail with a cutting torch. They also removed the 4 speed hump and a large section of the DS floor pan. This will all be repaired shortly.
