After all the wigglin of wires I did today and no leads yet makes me think about the ignition switch someone mentioned. I dug around in the column this mornin but nothing was obvious. No burn marks.
The turn signal cam/switch has no juice but the hazard switch still works, as do the lights
This is currently serving as my DD so I couldnt tear into it too bad this morning but come Monday I can totally disable it with confidence
Thanks for all the help fellas, it means a lot!
