Quote: Great work so far, looks like its come a long way. Keep up the great work, looking forward to seeing more progress. What are your plans for the drivetrain??
Thank you. I look forward to the body work to come to an end. I am more of a mechanic and I can't wait to get going on the drivetrain. I would like to get the car into the mid to upper 10's. I have a 400 BB which I tore down to the bare block. If the block is ok the plan is to stroke it. A local tranny guy will build me a stout 727. The car came with a 8 3/4 rear with a 742 center which will need rebuilding with larger axles and possibly shortened. I may find a donor rear and put the original one away...
