Frame bracket-floor tunnel are the only pieces that have to be welded. Original stick cars have a 2 stud brkt spot welded to the cowl for ease of assy when installing the clutch/brake assy. Doesn't have to be welded though. Most 71 and newer B/E cars also have a punched hole in the top of the frame rail that locates the frame brkt. If you want to shoot me an email I can send you a quote that you can use for your check list.
Dan
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
