Tis a double edged sword when advancing intake centreline , obviously what this does is advance all valve events , too much advance can have the exhaust valve open too soon , especialy bad when running low compression engines with slow flame travel , sometimes the split pattern grinds just make matters worse , the other problem is reversion through intake @ low rpms , not good for a street motor.
