Quote: Welding inverted , overhead , you need to use a FLUX core wire , no gas
This is BS ! Do you think all welders or welding shops switch units to do overhead welding ?
Lighten up Francis , with that Hobart welder he has he should to switch to a FLUX CORE wire for overhead stuff , not that the extra current is going to help when welding thinner metals ...
