I've heard that the metal dash frame in 74 had some slight difference from the 70-73 units. Any idea what that difference might be? no one seems quite sure. When you open the glove box is there a cable that holds it in the open position, or a curved metal bar thing?
Thank you.
Tav
I've parted out at least 5 74 E-bodies. I did not notice any difference in the dash metal frames. The glove box door is the same as the 70-73, uses a metal strap.
It is interesting, but around here 74 E-bodies seem to be the most common! Maybe more were exported to Canada?
